1 - 20 of 22 Posts
Hey guys, any idea about the chrome piece between the tail lights on the 08 wagon? Easy to take off? Easy to paint? Know where I can buy one painted, or better to just do it yourself. Would rather do it myself than pay for that non-sense. The only thing I hate about my wagon, the silly chrome plastic. ;D
i orderd the sti piece which comes painted to match the color from my dealership for like around $85 should be an easy switch it all fits the same.
No the two are different, the hatch has the Suby emblem incorporated in it.
Seth
Aside from the emblem, does it have the same lines? Curve / length / etc.?
Nope if you look at a sedan and a hatch side by side you can see the difference. I am sure if you want to do some modding and possibly filling holes, you might could make it work. I am not sure if the contour is right either though.
Seth
85 bucks?!?! painted?!?! its 154 at my dealer, and 192 online.
Don't forget, you also have to buy the Star Cluster emblem because the chrome is all one piece.......thats another $40
I'm painting mine DIY style, along with the painting the chrome trim on the wrx grille satin black. All the supplies (various grit wet/dry sandpaper, adhesion promoter, primer, paint, rubbing compound, etc etc) will run you less than 70 bucks. Plus you'll end up with lots of leftover useful stuff, and a can of colormatched paint for touch-ups down the road.
I painted the chrome piece yesterday. It took me several hours of hard sanding. I used 100 grit sand paper to sand off the chrome. After a couple hours it looked like this.
You can see that it is pink under the chrome.
Some more time passes by. And its black under the pink.
Now I primed it, I gave up sanding it anymore, there was still alot of chrome left (I got tired of sanding, I even used oven cleaner to see if the chrome would come off but it didnt' help). I went from 100 grit to 180,220,400,800, and then 1000.
After that, I waited 10 mins between coats.
And here is the finished product, picture quality isn't great but in person doesn't look bad at all.
I was soo tired afterwards, I was thinking this was going to be easy quick DIY but it ended up taking way more time. Chrome was a [email protected]#$d to get off.
Well I hope these pictures will help anyone else planing on doing this and hopfully have better luck getting the chrome off.
I actually didnt' get it all off and the paint came out to be just fine.
I'm going to see if a body shop friend can sand and paint mine; the satin white pearl isn't a color on the STI so buying one already done isn't really an option...
Rob
That sucks it is now 1.75.
I might have to do the do it your self method.
Check parts.com. It's still relatively cheap, but it's unpainted and you need the badge. That's where I got mine from.
1 - 20 of 22 Posts
