Installed mine today, took about 1.5 hours with airtools.
How I did mine:
Removed intercooler, downpipe, top uppipe nuts.
jacked car up, remove rock gaurd, heat shield, EGT sensor, then the passenger side header.
Took a little wiggling but then the uppipe came out without removing motor mount bolts or turbo bolts.
The fit on my Cobb uppipe was less than perfect and required a double gasket on the low side of the uppipe.
I highly recommend starting this with all new gaskets.. both header ones (pass side only) and both uppipe ones.. the stock OEM ones suck. (yes, they are different from the dealer)
I have no good pics other than a side by side comparison.
My opinion of it so far... little quicker spool as it really is only eliminating a few rough edges over the stock one.. and its cast aluminum so it will have some heat sink properties.
any questions, just ask.
