1 - 6 of 6 Posts
pre]Audio/Mobile Video
WIRE COLOR POLARITY LOCATION
Battery BLUE/RED (+) RADIO HARNESS
Accesory YELLOW/GREEN (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
Illumination YELLOW/BLUE (+) RADIO HARNESS
Dimmer WHITE/YELLOW (-) RADIO HARNESS
LF Speaker (+) GREEN
LF Speaker (-) BROWN/WHITE
RF Speaker (+) WHITE/BLACK
RF Speaker (-) RED/YELLOW
LR Speaker (+) RED/BLACK
LR Speaker (-) WHITE/RED
RR Speaker (+) RED/WHITE
RR Speaker (-) BLUE/YELLOW
Steering Cntrls NO
Speed Cntrl NO
Radio Security YES
Security
Battery WHITE (+) IGNITION SWITCH HARNESS
Ignition 1 GREEN (+) IGNITION SWITCH HARNESS
Starter 1 WHITE/BLACK (+) IGNITION SWITCH HARNESS
All Door Trigger BLUE (-) AT KEYLESS ENTRY MODULE BEHIND DRIVERS SIDE DASH NEAR STEERING COLUMN
Domelight Super BLUE (-) AT KEYLESS ENTRY MODULE BEHIND DRIVERS SIDE DASH NEAR STEERING COLUMN
LF Latch BLUE/ORANGE (-) AT KEYLESS ENTRY MODULE BEHIND DRIVERS SIDE DASH NEAR STEERING COLUMN
RF Latch YELLOW (-) AT KEYLESS ENTRY MODULE BEHIND DRIVERS SIDE DASH NEAR STEERING COLUMN
LR Latch YELLOW (-) AT KEYLESS ENTRY MODULE BEHIND DRIVERS SIDE DASH NEAR STEERING COLUMN
RR Latch YELLOW (-) AT KEYLESS ENTRY MODULE BEHIND DRIVERS SIDE DASH NEAR STEERING COLUMN
Trunk Trigger YELLOW/RED (-) AT COURTESY LIGHT IN TRUNK
Parking Lights VIOLET (+) AT KEYLESS ENTRY MODULE BEHIND DRIVERS SIDE DASH NEAR STEERING COLUMN
WILL ONLY TEST WHEN THE IGNITION IS IN THE RUN POSITION.
Low Crr Pk Lights BLACK/WHITE (-) AT STEERING COLUMN
Convenience
Please select another category
Remote Start
Accessory 1 YELLOW (+) IGNITION SWITCH HARNESS
Accessory 3 BLUE (+) IGNITION SWITCH HARNESS
Starter 2 WHITE/RED (+) IGNITION SWITCH HARNESS
Key Sense WHITE/RED (+) IGNITION SWITCH HARNESS
Tachometer BLUE (AC) AT IGNITION COIL HARNESS UNDER HOOD
Speed Sense GRAY/YELLOW (AC) AT ECM MODULE BEHIND PASSENGER SIDE OF DASH
Low Crr. Pk Lights BLACK/WHITE (-) AT STEERING COLUMN
Brake Lights WHITE/BLACK (+) AT SWITCH ABOVE BRAKE PEDAL
COULD ALSO BE RED/WHITE AT SWITCH
Reverse Lights BROWN/YELLOW (+) IN HARNESS AT LIGHT HOUSING
Horn RED/GREEN (-) IGNITION SWITCH HARNESS
Modules
WIRE LOCATION
Doorlocks/Windows
Power Unlock YELLOW/RED (-) AT KEYLESS ENTRY MODULE BEHIND DRIVERS SIDE DASH NEAR STEERING COLUMN
OR BLUE/BLACK IN THE DRIVERS DOOR BOOT HARNESS
PowerLock RED/WHITE (-) AT KEYLESS ENTRY MODULE BEHIND DRIVERS SIDE DASH NEAR STEERING COLUMN
OR LIGHT GREEN IN THE DRIVER'S DOOR BOOT HARNESS
LF Window Up BLUE/RED (REV) AT VEHICLE MASTER WINDOW SWITCH IN DRIVERS DOOR
LF Window Dn BLUE (REV) AT VEHICLE MASTER WINDOW SWITCH IN DRIVERS DOOR
RF Window Up BLACK/BLUE (REV) AT VEHICLE MASTER WINDOW SWITCH IN DRIVERS DOOR
RF Window Dn RED/BLUE (REV) AT VEHICLE MASTER WINDOW SWITCH IN DRIVERS DOOR
LR Window Up BLUE/YELLOW (REV) AT VEHICLE MASTER WINDOW SWITCH IN DRIVERS DOOR
LR Window Dn GRAY/YELLOW (REV) AT VEHICLE MASTER WINDOW SWITCH IN DRIVERS DOOR
RR Window Up BLUE/WHITE (REV) AT VEHICLE MASTER WINDOW SWITCH IN DRIVERS DOOR
RR Window Dn GRAY/WHITE (REV) AT VEHICLE MASTER WINDOW SWITCH IN DRIVERS DOOR
[/pre] [/center]
YOUR WELCOME
Discussion Starter · #4 ·
This should work for all versions... but never take a sheet for granted you still need to test and verify each wire... i just did an alarm with remote start and clutch bypass relay yesterday and all info was correct
I want that you hook me up? or explain how to do it?
1 - 6 of 6 Posts
