I was trying to remove my front grille to meddle with it to see if i can customise the stock grille, but i failed. I took all the pins on the top off, but i can't remove what seemed like pins at the bottom of the grille connected to the front bumper..
any help?
There is 4 clip and 4 screw holding the grill
You already found the four clip on top, the screw are a PITA to get
Dealer install sheet say that the front bumper have to be removed, its pretty easing but i thought it will be long so i just removed the oil pan plastic cover and reached the screw by squeezing my arm between the bumper and the rad
It was easy that way cause i had the car on a lift... i guess if you have to crawl underneath you better just removed the bumper...
i will try to scan the install sheet of my grille and post it here
I just stuck my arm between the bumper and the grille. I also had a small snowboard tool handy so removal of the screws was simple enough. Hardest part was putting the screws back in... which I never did. Has held strong for a few hundred miles so far.
damn w/o putting the screws in mine didnt line up right, it was all hanging forwards. the install is super easy but prepare to get your arm scraped up!!
anyone have pics of the install?
nice... i'll jack my car up when i'm free!
is much much easier if u remove the bumper
haham meet up and show me... i'll try again when i've gothte timehaha
initially i also force mine hand in unscrew to bring out the grill but when i want to remove my headlight to spray, i still got to remove bumper hahaha... den found remove bumper is much easier. haha
