1 - 5 of 5 Posts
Do the Cobb shifter bushings, or other similiar ones from Rallitek, Perrin etc. (the pair of bushings that gets put on from underneath the car, not the ones put on from inside the car) add much to NVH?
Any time you add stiffer bushing you will feel more vibration.
I have the Cobb Short Shifter and the bushings and things feel the same to me....No more vibration with these in than the stock.
FWIW I have the kartboy short throw shifter and the thing is noisy as all hell. lol
I checked all the torque specs on the linkage bolt and everything was perfect when I installed it. It just makes everything in the trans louder. And it vibrates in certain gears. Just the way it is I guess.
Lube that bushing up.
1 - 5 of 5 Posts
