1 - 5 of 5 Posts
I'm on the verge of ordering up a downpipe, but am not sure which to get. I was gonna get the Perrin because it seems like a quality piece, but the Cobb unit is $70 cheaper. The difference I can see is Perrin's has two cats versus one on the Cobb. I do want a catted DP, so Invidia and TurboXS are out. Anybody else make one with cats?
If I got the Cobb, I could get it and their heat shield and still come out less than Perrin's...
Thoughts?
Rob
Many other companies do
The ones for all LGTs fit. Even on STis we have put them on.
Harman Motive
Invidia does have a catted
Vivid Racing
AVO
TurboXS
There are others
Just keep looking and take your pick. Divorced or not, ceramic vs metallic, 1 vs 2 cats, upper vs lower position, tapered end to fit OEM midpipe or not. 3" 4"<--I've seen this somewhere but can't remember off hand. Then compare by price.
Hope this helps you expand your choices
Why try a Megan Racing DP instead? They make one for the mt LGT and that should bolt right up. Its also only $200 so its more than 1/2 the price of either the Invidia or the Cobb.
Why try a Megan Racing DP instead? They make one for the mt LGT and that should bolt right up. Its also only 0 so its more than 1/2 the price of either the Invidia or the Cobb.
I was under the assumption that Megan had not yet made a catted version. However, most companies as well as Megan are comparable in terms of pricing for non-catted dp.
Just another option to consider.
I'm on the verge of ordering up a downpipe, but am not sure which to get. I was gonna get the Perrin because it seems like a quality piece, but the Cobb unit is cheaper. The difference I can see is Perrin's has two cats versus one on the Cobb. I do want a catted DP, so Invidia and TurboXS are out. Anybody else make one with cats?
Thoughts?
Rob
Get the Cobb.
Cast bell mouth = hold heat better and extra 02 bung is on the bell mouth for tuning.
I have it and love it.
1 - 5 of 5 Posts
