1 - 6 of 6 Posts
Hello does anyone know the ballpark figure for changing the rear drums to a soild disc?
i'd say find a crashed 08 impreza (probably will take a while) wich has disc brakes and swap that's what I did on my mazda, or if you want to invest buy the whole kit at your dealer, once you have everything shouldn't be hard at all ;D
you'll need:
4-disc brake booster (unless they're the same size on the 2disc/2drum and 4disc - but I doubt that)
plus rear knuckles, calipers, rotors, etc, and it'd be a good time to replace the lines with SS lines since you're messing with the brake system anyway.
also if you have steelies, make sure it all fits... though I don't see why it wouldn't if the front discs fit.
Do you have an 08? I thought they already had rear disks...yes they do!!!
08 Imprezas come standard with rear drum brakes. If you get the Premium package, then you get disc brakes all around. 08 WRX comes standard with 4-wheel disc brakes.
OIC...I thought we were talking about a WRX here..my bad
1 - 6 of 6 Posts
