1 - 6 of 6 Posts
Hey there. What size are our OEM lug nuts? I went to torque them after having a mechanic put on the STI pinks and found out I don't have any metrics that size. So help a brother out with a dumb question. ;D
Discussion Starter #2
Never mind, I found out by going to a auto parts store and comparing my small tire iron in the back to the sockets.
A 19mm socket turned out to work perfectly.
And, 19mm also happens to be the same as 3/4" in case you don't have the metric version around.
I thought you meant the thread size, which I believe is 12mm.
Rob
Its a 19mm. I know becuase i broke my only 19mm 6pt breaking the camber nut loose on the front strut. Couldn't put my wheels back on, and had no means of getting to a hardware store, let alone work, for the day. The mountains in utah are awesome until you need a something that's not a block away...
1 - 6 of 6 Posts
