1 - 4 of 4 Posts
Connections:
Subaru 20 pin connector pin out:
(This is Subaru's numbering scheme, looking at the pins side of the car's harness — car's wires pointing away from you)
Code:
1 2 3 4 5 6 7 8 9
10 20
11 12 13 14 15 16 17 18 19
Pin Assignments:
Code:
Pin Function Car's Color EIA Color
1 Illumination Violet Orange
2 Dimmer Black/White Orange/White
3 +12 Accessory (Ign. Switched) Yellow/Red Red
4 Steering Wheel Controls – Brown —
5 Left Rear Speaker – Red/Black Green/Black
6 Left Rear Speaker + White/Red Green
7 Left Front Speaker – White/Black White/Black
8 Left Front Speaker + Blue/Orange White
9 Antenna Booster Yellow/Black Blue
10 Ground Black/Blue Black
11 CAN data bus Green/Red* —
12 CAN data bus Pink —
13 (NC) — —
14 Steering Wheel Controls + Yellow —
15 Right Rear Speaker – Red/White Violet/Black
16 Right Rear Speaker + Gray/Green Violet
17 Right Front Speaker – Green Gray/Black
18 Right Front Speaker + Brown/Yellow Gray
19 (NC) — —
20 +12V Battery (Constant-on) Blue/Red YellowNotes:
EIA is a standard for wire colors used by nearly all aftermarket head units (HUs) and harnesses
Illumination = +12V when headlights on, otherwise open-circuit
Dimmer = variable voltage from 12V (dimmest) to 0V (brightest) [yes, backwards — not a typo], same as instrument panel lighting
* Subaru's wiring diagram shows pin 11 wire color as "LgR" for "Light Green/Red"
your welcome ;) i figured at least one person would use it. it should be a sticky
Ok where do i start,lets see this is probably one of the most usefull posts on this website and it got 1 reply,thats weak!!!! We just did an old school Rockford 200s and Kicker CVR 10 install this weekend(they were free wtf) and it probably took a whole hour. i had to tap into rear speakers and run a remote to factory headunit. well i givin him +1 for it, very usefull!!!!!woulda been ther for hours, thanx yo!! ;D
1 - 4 of 4 Posts
