IF YOU NEED YOUR CAR WORKED ON .you can trust PROJECT IMPORT to install anything on your car. he will walk you thru step by step as he does the work which makes you feal good.installed( invidia 3in downpipe. samco turbo inlet hose, blitz air filter, cobb access port). after all that it still doesnt run right. you have take it HB SPEED and put it on the dyno they will measure everything to give maximum power with no boost cuts. total power 290 hp 307 torque. it runs unbelievable. i would trust both PROJECT IMPORT and HB SPEED with my car.
