1 - 4 of 4 Posts
hi
anyone know what fuel injector subaru is using and does changing the injector help the FC or power gain
maybe something like bosch ev6 or something similar , any recomend? . mine's a 1.5R . THANKS
oic thanks for the info
BTW read on the web that by installing a fuel regulator you can alter the spray pattern of the fuel injector
and by lowering the fuel pressure you can alter the AFR causing it to run lean thus saving fuel.
is that true ?? if that is the case how low is too low and how high is too high
1 - 4 of 4 Posts
