RDKLSTi – 518whp/492wtq (MD) 2008 STi
2008 Subaru Impreza WRX STi - rdkls STi
Follow;
fb/rdklsti
ig/rdklsti
Build thread restructured. First post will always have my latest update, the rest will be on my site.
://sti.rdkls.com
Dyno
Longblock
Power
Fuel
Electronics
Drivetrain/Chassis
Suspension
Brakes
Wheels
Interior
Exterior
Roof Rack
Follow;
fb/rdklsti
ig/rdklsti
://sti.rdkls.com
Dyno
- TO BE DETERMINED... old #'s below.
- Tuner: William Knose, Delicious Tuning
- Dyno: Mustang AWD, Infamous Performance
- Weather: 83 Fahrenheit, 44% Humidity, 646ft Elevation
- 15 Psi — 367whp, 326wtq -
[*]23 Psi — 454whp, 391wtq - [S#]
Longblock
- Outfront Motorsports closed deck EJ257 with pinned mains
- Outfront Motorsports AVCS pin service
- Outfront Motorsports spec 1/2" ARP head studs
- STi JDM 12mm oil pump
- Molnar 79mm billet crankshaft
- ARP 2000 case bolts
- CP Pistons - 99.75mm 9:1 (coated crowns) with upgraded wrist pins
- Manley Turbo Tuff I-Beam Rods
- Race ported heads (by SoCal Porting)
- GSC stage 2 cams
- Supertech dual valve spring & titanium retainer kit
- Supertech +1mm stainless intake valves
- Supertech +1mm inconel exhaust valves
- Bowl blended heads (for larger valves)
- King rod & main bearings
- Gates racing timing belt
- Killer B oil pan, baffle & pickup tube
- JE/Athena head gaskets
- WPC Treatment on select components
Power
- Rotated GTX3576R
- Perrin rotated 2" uppipe (T3)
- Custom rotated 3" downpipe with QTP electric cutout
- Perrin 3" intake with K&N filter & pre-filter
- Perrin EL Big-Tube header
- Perrin EBCS
- Perrin/Setrab oil cooler
- Tial MV-R 44mm EWG
- Fluidampr Crank Pulley
- TurboSmart Supersonic BOV
- Maddad Essentials Street Series Cat-back
- TurboXS FMIC core with custom charge piping (by KPowered)
- TGV delete & port, throttle body & intake manifold ported (by SoCal Porting)
- Rotated STi intake manifold
- KSTech 9.5mm phenolic spacers
- Koyo Radiator with Mishimoto hoses
- Perrin AOS
- Perrin Thermal turbo & uppipe blankets
Fuel
- Radium pump hanger with (2x) AEM 50-1200
- Radium multi-pump regulator
- Radium top-feed rails with pulse dampeners
- Injector Dynamics 2000CC injectors
- Fuelab 6 micron micro-fiberglass element
- Continental Ethanol content analyzer
Electronics
- DeliciousTuning FlexFuel Kit
- Ecutek ProECU
- AEM IAT sensor (tapped just before throttle-body)
- AEM 5-bar MAP sensor with Cobb MAP sensor adapter
- NGK 1-step colder plugs
Drivetrain/Chassis
- Driveshaft Shop Carbon driveshaft
- CompClutch Rigid Twin-Disc clutch
- Torque Solution pitch-stop
- Beatrush engine mounts
- Beatrush transmission mount
- Whiteline gearbox mount bushings (positive shift kit)
- Whiteline steering rack bushings
- Whiteline Rear Diff fully polyurethane bushings (front & rear)
- Whiteline Rear Subframe bushings
- SuperPro Rear LCA bushings (inside & outside)
- SuperPro Rear Trailing Arm bushings (front & rear)
- SuperPro Rear Toe Arm bushings
- Kartboy shifter bushings
Suspension
- Tanabe Sustec Pro S-OC coilovers
- Whiteline 22mm adjustable front & rear swaybars
- Whiteline front control arm inner-front bushings
- Whiteline anti-lift kit
- Kartboy front & rear solid endlinks
Brakes
- Grimmspeed master cylinder brace
- Goodridge stainless steel lines
- StopTech Power Slot front & rear rotors
- Hawk HP+ front & rear pads
Wheels
- SSR Type-F matte black 17x9.5 +40
- Michelin PilotSport PS2 275/40
- McGard spline drive lugs (black)
Interior
- ATI triple gauge pod
- -Innovate MTX-D Boost/Shift Light
- -Innovate MTX-D Oil Pressure/Temp
- -Innovate MTX-D EGT
- SMY gauge bezel
- -Gauges: AEM UEGO Wideband
- 15% tint all around
- Weathertech floor liners front & rear
Exterior
- GTSpec aluminum undertray (splashguard)
- Hexis 3D carbon roof wrap
- Hexis 3D carbon front bumper sectional wrap
- HTAutos full lip kit
- Rally Armor V2 mudflaps (black/grey)
- Painted OEM grill/mustache
Roof Rack
- Subaru factory rails
- Inno medium fairing (40")
- Yakima Frontloader bike racks with lock cores
2015, Dec 7 - Engine bay complete and first fire video.
