1 - 12 of 12 Posts
2. attempt :cheesy:
Hy, my name is Simon and I'm a car enthusiast in car hatin' Switzerland.
After reading through the forums and owning my first STI for several months I thought it's time for a journal. although it's not going to be a huuge story.
I went through different cars, all hondas just until now, when a bougth my SWP sedan. hgh, the guys in my crew are still pissed..
started with a Honda CRX, modded it sligthly.
then I had an Honda Integra Type-R with the B18C6 engine.
After that I went for the hothatch CTR FN2
I had it for 3 years and had to decide, either to build a strong engine or go for a car, which has the power right from the factory.
'cause in Switzerland parts such as headers, hi-flow cats, air-intakes and so on are illegal, it would have been a PITA to build the honda.
although the sleeper-kind-of-car (nothing special on the exterior) would have been nice.
the K20A in the CTR is a good base and with NA tuning you can get around 250whp..
but then, I ran into a STI and decided to go with the factory solution.
next to the STI i built up an CRX with an B18C6 out of an ITR with my cousin, it's nearly finished an will be a track dedicated fun car. pics on requests..
I try to have some sort of organisation in this topic, please give me a second..
Discussion Starter #2 (Edited)
Modlist
Modlist
Interior
Alpine INE-S900 Navi mit 6.5" touchscreen
Prova D-Shaped Alcantara Steering Wheel
Prova SI-Knob
Maddad 3-1 Gauge (boost, oiltemp, EGT)
Zerosports Gauge Mount for GR-series
TWM Titanium Shiftknob
Carbon Fiber Shifter Surround
Exterior
de-winged with second tS trunk spoiler
Perrin Shorty Antenna (radio empfang even worse..)
Black Fender Badges
STI V-Lip
Royaltuned CF Exhaust Heat shields
RA Mudflaps
Wheels
G-Force 18x9 (2 sets, 1x Dunlop SP600, 1x Yoki AD08)
OEM for winter
Rear fenders rolled
Suspension
KW V3
Perrin Rear Subframe Lockdown Kit
Perrin Swaybars Front & Rear
Kartboy Endlinks Front & Rear
Brakes
Mov'It drilled Discs
Pagid RS29 Front
Ferodo DS2500 Rear
Goodridge SS Lines
Engine/Exhaust
CRTEK with AEM Filter
Invidia Q300 TBE ti tips
Grimmspeed Turbo Heat Shield
E85 Map
Perrin Radiator Shroud
ready to install:
Perrin Shifter Bushings
Grimmspeed Master Brake Cylinder Brace
ready to install
wanted:
upgraded radiator
I surely forgot something..
Discussion Starter #3 (Edited)
Installation Pictures
This image has been resized. Click this bar to view the full image. The original image is sized 800x451.
plus a pic with the OEM roof rails for my boards.
the exhaust heat shields by royaltuned aka jared.
so nice handcrafted pieces. have a look here:
ImageShack Album - 9 images
This image has been resized. Click this bar to view the full image. The original image is sized 1280x722.
Real CF Shifter Surround
Discussion Starter #5 (Edited)
Pictures
2011:
some Pics in the middle of Switzerland:
2013 as seen in SWP picture topic
Is your map a protune or off the shelf like cobb?
the maps are protuned ones because we can't use cobb on EUDM cars. ECUTEK was used.
Can't state the mods in detail due to the regulations here..
Also, this is measured at the crank, so it doesn't compare to the whp you guys use.
engine is still on stock internals, around 21 psi of boost.
I love all the GRC stuff interior wise plus all the carbon fiber accents! +1
Awesome job on the build thread. Glad to see you put one up for us to see :D
You seriously have a great build going there and curious on what you have that you can't post :p
You're 100% correct about not having enough CF ^^b I wish I could afford it ahah Love the wingless trunk looks way better.
It's a nice piece and i went for it because i didn't like a-pillar mounts (airbag).
Also, ATI and SMY would force you to get more gauges. I trust the tune to keep AFR in range so i just wennt for oil and egt temp and boost.
In the earlier productionseries there seemed to occur problems with the stepping motor, but mine just works fine.
I even bought a second one for the track car (crx, soon to be turbo'd).
For a 'single' gauge you still need a proper mounting solution. MB discontinued their GR single pod and zerosports is pricey. But, a 3 gauge setup with mounts will be equally in pricing if not more..
1 - 12 of 12 Posts
