1 - 17 of 17 Posts
dealer screwed up my paint and denied they did it so I'm stuck fixing it.
got a rattle can of obsidian black pearl made by a local paint dealer... here are the results:
still have to buff out the runs and then do a clear coat. I'll post pics of the ongoing process. the 08 factory paint is junk.
How much did that obsidian black pearl made by a local paint dealer cost?
$19 for a large rattle can
it was Sherwin-Williams
they have a store that ONLY does automotive paints... so if you go into a normal SW store they won't know what you're talking about unless you have one in your city that is the same and only does auto paint.
Damn I don't think there one in MA.
Thanks
I look it up and theres few in MA. This is great i'm going to get some next week.
keep in mind:
- it's automotive paint (not enamel like normal spray paint)
- it's just a base coat (you'll need to buy separate clearcoat)
if you've never painted with automotive paint before, I recommend looking up some information
if you're getting obsidian black pearl metallic (what the 08 WRX 'black' is) -- the code you'll need is 32J
rear area
like where the gas filler door is but the opposite side
also, update: turns out they didn't mix the paint right ... so I'll have to start all over.
after one layer of clearcoat I noticed the new paint was actually GREY and not black... also note the cloudy streaks from the humidity! (they gassed out eventually)
went to the paint store and they remixed the paint to the right shade of black and gave me TWO cans for free. wow.
I'll be outside painting ;D
I'm going to get a sti wing and try to paint that.
just make sure they match the paint first. if they mix it by Subaru's specs, it'll come out grey (they list too much white for the mixture) -- that's what I had to have them do... they ended up mixing a lot less white into it and it matches perfectly now
I'll have to remember that.
1 - 17 of 17 Posts
