I’ve got a 2018 WRX and I recently installed a Cobb AOS and Cobb SF intake, car sounds and runs perfect, at least as far as I can tell, nothing seems wrong, running the Cobb stage 1+ 91 ots tune and in the process of getting an etune, but I see crazy high af learning and af correction values. Under load they fall in the acceptable range, but at idle af learning usually sits around 12-18, and af correction will just as high or low as +\- 25 when letting off the gas or switching gears.
Wondering if y’all could give me some insight about if this is a problem or normal, and if it is a problem what would be the causes. I attached some logs along too, 11 is crushing, 12 is idle, and 13 is 3rd gear redline. Update, I can’t post them, I’m new here so if anyone knows why it doesn’t like the extension lmk
