1 - 20 of 27 Posts
Can anyone tell me the difference between these two?
Product ID: HS08SW1DPC
Invidia Divorced & Catted Polished Stainless Steel Downpipe For 2008-10 Subaru WRX & STi
Details
Product ID: HS08SW1DPN
Invidia Divorced Polished Stainless Steel Downpipe For 2008-10 Subaru WRX & STi
Details
IAG Subaru Performance: Exhaust,Down Pipes
One is catted, the other is not.
Any performance over one or the other I've read both sides and don't see which one is more over the other.
The one without the catalytic converter will net you a few more horsepower. However, if you have to get emissions tested/inspected you won't pass without a catalytic converter (unless you have a hook up or the person inspecting your car is an idiot/ doesn't care). Also, many people who have gone catless have had problems with boost creep.
Thanks! Makes the choice much easier for now, if I go w catless later on ill see how the inspections go.
Another question about downpipes:
I read that the divorced wastegate will not work with a bigger turbo such as APS, anyone know if this is true?
Not true, the only time the downpipe will not work on a turbo is if you are mating it to one that doesn't have the subaru hotside.
Do you have any recommends on a upgraded turbo that would still work this setup? I'd rather not buy two dps if I don't have to?
ATP, Blouch, FP, AMR etc... all make turbos that will work with the downpipe. How much power are you looking to make? How much money do you have to spend? What are your goals?....are all questions you'd need to answer before anyone can recommend a turbo.
I'm looking for power ranges equal to or more then the STIs, so my goal and budget is looking between 240awhp+ i don't see myself going into the 350+ range w an 08 sedan.
My goals are to make my dd into a aggressive dd with posibilities of rally depending on my geolocation.
You can hit 240whp with your current turbo. I see no reason to upgrade it, if you want a little more then slap a stock 09+ vf52 on.
Really w the stock I have now?!!! If that's the case then what are the whp with the vf52?
Discussion Starter #14
Hmmm more turbo.. Haha! Well that's for down the road. But back to my question, is there a need for downpipes if you have a turboback or viceversa? Now that I know that Invidia will work as a dp I'm not sure which to spend the money on? TB or DP?
TB includes the cat back exhaust (cbe), a downpipe only replaces the stock one. You'll need a 3" adapter (Grimmspeed) to mate the 3" downpipe to a stock cat back. The catback has minimal gains at this power level, it is more for noise and looks.
Hmmm have you experienced any difference between just a dp and cbe to a tb?
Also is there a significant difference between single and dual cbe from the tb as far as performance goes?
Yeah,you need bigger / better turbo and THEN bolt on parts for that model year.I had one and traded it when the more powerful motors came out.2008 wrx for much Improved 2010.
So now I'm confused, I have plans for a bigger turbo but I want to work on the exhaust first. Do I go downpipe and cbe, or straight to turboback?
of course you can do TB exhaust first!but it would be wiser to get a used VF52 or better turbo from forum User and do it all one time with real gains.
1 - 20 of 27 Posts
