1 - 4 of 4 Posts
So I just got my Invidia Catless DP in but still waiting on my SPT exhaust which I nor the dealership have any idea when it is going to come in. I want to put in my DP bad but if I do that will I need a tune for it? Would it be better to just wait for the SPT to come in and put it all on at once then run a Stage 2 Map? Its sitting in my garage and I want it on haha... Thanks!
Whenever you change the amount of air going in and out of your engine you should get a tune (IMHO of course). I would definitely NOT put on a downpipe without getting some sort of tune or EM unless of course you have an affinity for CELs.
catless DP without a tune is going to throw a CEL or worse give you boost creep or run your engine lean which could blow it up...
get a tune! it's well worth it.
Wait, then get a tune. On a side note: The OTS Stage 2 maps are not meant to run catless unless stated. Normal Stage 2s are catted and if you run these maps with a non catted dp, you might experience severe boost spikes due to the lack of backpressure.
1 - 4 of 4 Posts
