1 - 18 of 18 Posts
Your order has been received and will be processed.
(Please print a copy of this page for your records)
Your order contained the following items:
1 x AccessPORT 08+ WRX/STi NEW! - Stage One Map - 93 Octane [PSP-ENG-918]
An authorization was taken for a total of $704.64.
Super excited, can't wait to try it ;D
I know I can't wait to get one too. Let us know how it works out for you.
Seth
Nice move man youre gonna like it. give the ecu some time to adjust and after you put a couple miles on her reset the ecu. This seemed to make the AP more noticeable.
I don't have an AP yet, but how do you reset the ECU?
Discussion Starter · #6 ·
^^ Reset ecu is done by removing the neg, batt cable for a min or so... This will not unload a reflashed map however, that must be done witth the AP :)
Discussion Starter · #8 ·
Has anyone ever seen more than 13 or so lbs.? I'm not getting anywhere near the target of 16psi. ???
Discussion Starter · #12 ·
^^ What map are you using? Perrin sent an updated map today with increased wastgate duty cycle. I'll try it out tomorrow
Yuck. Two pulls on the way to work. Perrin Stage 1 map (no other mods...YET!!). Highest boost I could get was 11.7........ So it could be that something is up with the map or something is up with the live data readings from the AP. This map is going to go bye bye in 2 weeks anyway so not too concerned. Stage 2 PDX map here I come.
Discussion Starter · #16 ·
I received an updated map from perrin.... Rev 2, seeing 14.4 yest. and now 14.7 today. I think it has a longer learning curve ;) But 11.7 is not good, thats lower than stock :(
1 - 18 of 18 Posts
