541 - 560 of 574 Posts
145....track, is that the local expressway? We've got a few of those around :lipsrsealed:
I've been shutting mine if I go over 55; figured that's what it said lol. Guess I'll have to test it out now.
no worries, you're good well above that. it says to not open at speed beyond (i forget exactly what) so you're good. at those speeds with a window just slightly down in the rear you are moving a TON of air in the cabin though - pretty ridiculous, haha!
Discussion Starter #542 (Edited)
Turbosmart bpv and Grimmspeed master cylinder brace on
Had a little free time today to install the Turbosmart bpv and Grimmspeed master cylinder brace. The Grimmspeed piece is MUCH easier to install than most make it out to being as long as you have the right tools and work room. Once the intercooler piping was out of the way, it was a breeze but I did have the wife come help me thread the top left bolt, there was no way my mitts were getting in there.
Advanced Key's smart keyless entry system + push button start module showed up. I opened the box to check it out....then closed it right back as I am definitely not installing it. I'm sure I could but that is why I have a mobile audio guy that will come take care of it for me :laugh: Thanks again to Yanev @ SMY for hooking it up!!!
push to start, balling. haha. you gonna disable the lock for good or just do the shaved key trick?
Discussion Starter #546
Balling...hardly. I'm not completey set on anything yet but I'll probably end up removing the spring. The car is insured and they would have to bypass the Advanced Key's setup to start the car...not sure how difficult that would be though.
i'd wire in a hidden switch to disable the entire system when you park the car overnight and if you ever have to leave her alone in sketchy areas. just a simple thing to do to ensure one more level of success with the install.
Discussion Starter #549
who is your mobile alarm installer? contact? rate?
texted you
not too many sketchy places around where the car gets left but it's not a bad idea. I'll definitely post about the hidden switch when it gets installed and let you all know where its at lol
texted you
Wont be hidden if you show us where it is!
Contemplating the PTS system myself but a local shop has an aftermarket one that does hands free door unlock and remote start. Does the oem have that?
Discussion Starter #556 (Edited)
Ok so is the kit you got oem or 3rd party?
I have the Advanced Key's kit Advanced Keys - AK-104B Smart Key with Push Start System
The Killer B Motorsports oil fill relocation kit showed up yesterday; like all Killer B products it is definitely a very well made/designed top of the line piece. I'll have it installed this weekend and will post more photos then.
Trunk lip showed up today....still not sure if I will install it but for the $$$ I couldn't pass it up. I'm still tempted to pickup the TS spoiler and call it a day.
Been following you and Marcos build for awhile now, out of both your guys experience what boost gauges have you tried and what ones have you disliked and why? My maddad fell through so been searching for alternative.
Discussion Starter #558
hey man, do you have any issues running your spt with the whiteline sway?
