Hi All,
My MY01 WRX has only 6lbs boost.
I have checked that the boost solenoid is working. Opens when energized and seems to have about the right ohms.
Did a leak test on the intercooler and bypass valve. All was working as it should. Bypass valve opened at about 6lb with no pressure on back side, held pressure with even pressure on both sides.
Wastegate seems to be operating freely.
No check engine codes.
Pill is correct size and installed in correct line.
Any ideas where I should look next?
TIA
Ryan
