1 - 14 of 14 Posts
Perrin FTW... at least thats what i'm getting for the sedan.. stealth one :)
Perrin only has the fartcans for the sedans last I saw...
this might be true but at least its a 3" which is hard to find for the sedans... all of them are 2.5
which is what i'm going to be doing so no need to buy a 2.5 then have to upgrade to 3 when i upgrade my turbo..
That's because 3" is overkill unless you seriously upgrade your turbo.
Even with a slightly larger turbo 3" is overkill. You have to seriously go larger to make it beneficial. 2.5" is sufficient unless you are going for monster power.
I dont like the sound of the sedan at all. It lost almost all the boxer rumble. The 5 door sound's good though. I know they listen to customer from certian forums. I hope it gets changed.
wait for cobb, its well worth it!!!!!!!!!!!!!!!!
COBB exhaust is a myth. It doesnt take a year to fab up some pipes.. :p
We're talking about turbocharged engines.. overkill doesn't really exist. We aren't talking about tuning for pulses and optimal exhaust velocity like with a naturally aspirated engine. There is no scavenging effect with a turbocharged engine. There are no drawbacks other than having a pipe sit .5" lower to the ground underneath the car.
The fact is, the 2.5" and full 3" exhausts cost roughly the same, while only a few downpipes (ie:Cobb) reduce down to 2.5".
Ya, I agree, i have a 3" exhaust that splits to 2.5 out the back made for a legacygt that i modded slightly to fit my sedan and it sounds wicked, and i pulled really good numbers on the dyno. I put my exhaust on before my dp and cai and it made my turbo spool soooo much quicker. My exhaust doesnt sit any different then the stock either.
1 - 14 of 14 Posts
