1 - 14 of 14 Posts
I am seriously in the market for a new or slightly used wrx when my truck sells. Yesterday I went to my trusted subaru dealer and asked about the wrx vs sti. The salesman and subaru techs are active engine builders and know their stuff. They said for my sake the sti wouldnt be worth it because of maintaince maily pointing out That the brembo brakes are expensive and expensive to work on..and afterall I'm not racing the car so why would I need them anyway? Plus as of right now I can't even hardly drive a manual vehicle...need to learn. I am very set on a wrx of some variation at the moment...they say the ownership of these cars isn't as cheap as I thought?
Need to run 93 octane and $100+ oil changes...replacing clutches and fast wearing tires...I'll be honest..not sure I'm prepared for all this...can you guys chime in?
You want to run the best gas at your disposal, whats an extra .10 a gallon.... $1.50? If youre paying $100 for an oil change, you could go elsewhere or do it yourself, there is only one clutch and its awd...its what they do. Call your insurance and get a quote for both cars and see what you can afford.
- Save yourself almost $8K by going with a WRX vs. the STI. You should save even more after factoring in the insurance savings.
- Use that $8K for mods that'll allow your WRX to embarrass a stock STI.
- Peruse the forums here to get educated on how to: a) drive the car without frying the clutch, b) do the routine maintenance yourself, c) choose mods that offer the best bang-for-the-buck.
- Hook up with some local Subie guys for help when you need it.
- Get used to paying about $4 more per tankful of gas - it's definitely worth it!
- Tires should last about 25K miles unless you autocross or drive like a maniac.
These cars are inexpensive to own & maintain given their impressive performance. Just do a bit of research - the car's only weak points are relatively minor nuisances.
What Zulu said. The Sti is awesome but yes, the WRX is a fantastic rig and you can save the 8k then spend much less than that to get an incredible car.
I was in your same boat, went with a used 2010 WRX and now have a personalized vehicle that I enjoy the crap out of driving everyday. I've spent WAY less than 8k on mods, did all the work myself as a green mechanic with the support of the community info here, and not only is my car faster than a stocker STi.....I know my car very intimately now and that's something you just don't get if you straight up buy a car and be done with it. Now that's not a bad thing to do but, in my opinion, I've had a much more valuable and engauged experience by going WRX and modding vs. buying an Sti that I can't mod because of budget. Plus, if you blow your whole nut on an Sti and have no funds left to upgrade......your car still looks like every other Sti that year!
Either way, you'll love your car I'm sure. They are both great right out of the box but, the WRX can go from great to astounding for a very reasonable amount of work and $$.
OK, enough of me on my tripple espresso rant! Good luck with it all, hope to see you around here soon!
Giddyup!
If u want a car that performs like a beast be prepared to pay a little more for gas and oil changes. for me that doesnt bother me one bit. I dont know where these outrageous $100 plus oil changes are maybe synthetic oil cost much more where u are??? anyways even if I had to pay $100 for a oil change my wrx would still be worth it and if I was able to do it all over again Id still take my wrx over a sti. just for the fact I prefer straight line acceleration
I pay... $26 + $6 filter. Rotella T6 and OEM filter.
If you know how to work on your car or have the the tools and want to learn, maintenance is very easy and cheap if you do it yourself.
Like ppl said, call your insurance and get a quote on both. Then factor what you'll be paying monthly and see which of the two is within your means. If they both are, take the sti hands down. The douchebag salesmen look like they were seriously exaggerating.
And I lol every time someone uses the regular vs premium fuel argument. Is 20 cents more on average and the tank fills with about 12-13 gallons. What's another $2 and change for performance?
^ +1 what he said.
I use Castrol Edge (synthetic) & OEM filter. Takes about 20 min from start to finish due to the under-engine tray having to come off first.
I seriously appreciate the feedback guys. I think if I change my own oil it will help for sure. I am not worried about tires, I understand they wear. My main worry are the brembos..I plan to go talk to the techs again tomorrow..I'd love love to have an sti but will these brakes really wear that fast? The subaru tech did say since they are brembo you can't just to to auto zone and throw cheap pads on them, and I understand that completely but what about other costs?
Try asking on iwsti.com; since this is a wrx forum. Everyone will try to persuade you to get a WRX over the STi...
@zulu what filter do you use? I've been using those Fram filters; a wal-mart employee suggests me to use a Purolator
Brake pads for the wrx or sti are "around" the same price. Id suggest not running to autozone for either cars. I think you should try another dealer or tech...
Crimson, your tech doesn't know what he is talking about. Brakes wear as brakes do. Brembo pads can be more expensive because they're larger and there are higher-end options, but that's it. Rotors are a little more expensive as well since they're larger, but you have options and a lot of time before those need to be replaced. You 'can' use autozone pads for $20 or whatever and they'll stop great -- just don't track or abuse them too much on the street. But, then, I'd just spend $100 and get a proper set.
dScoobs, I use the Mazda RX-8 black Tokyo Roki filter.
1 - 14 of 14 Posts
