1 - 2 of 2 Posts
hey this is my first post but if any body else is run a cobb tuned map stage2 and you have a catless downpipe and you are throwing this code. yesturday i called cobbtuning and they told me they will have new maps for this problem and so far this this maps work and im using 93oct stage 2 map ;D so just telling everybody else they got the maps on there website and hopefully they work for you
Discussion Starter #2
Re: p2044 code accessport tbe stage 2
i forgot to say what they did on the old stage 2 map the target boost is 16+or - .7 and boost fuel cut was set at 17psi
and the new map is set at 16 psi or so and they rised the boost fuel cut and even though it set for 16 im still hit 17psi to 17.5psi and no cel
1 - 2 of 2 Posts
