Eclipse Calculator ? Eclipses in Tucson, Arizona, U.S.A.
Spaceweather.com
For anyone still using this site there is supposed to be a partial eclipse today. The first link should allow you to change the zip code to get an accurate local time of when it starts. Those in central time will get the best view as the peak of the eclipse will coincide with the sunset but those in new England are going to see just a few minutes as the sun will be setting when it starts so make sure you're at a clear and high elevation
For those in mnt look around 230, peak should be around 330 ish and the last bit will be around 415
