The revised map was emailed to us, bc we've not seen the target boost of the perrin map ;) It contains a rev. for a little more wastegate duty, so far rev 2 is working best.
I only saw like 13.5 - 13.8psi with the first map, the second was saw 14.5 max. Could have just been the ecu learning better after the reset though :-\
I'm reaching higher boost levels with the rev2 map. I haven't checked in about a week but when it was installed I hit ~13.5psi, it's probably higher now since it's had time to learn. V1 I was barely hitting 12psi... I dream of 16psi, I bet it's a great place to live.
I'll bet it sucked to see only 12 ... thats only stock boost :-\
Are you using 93 oct.? I'll send you the map I have. I saw 14.7 today :-\
