1 - 5 of 5 Posts
anyone install the mtx re-q5 or somethign similar? i was curious what you used for the facory wiring schematic to match everything up right. i dont think its goin to be too hard, just wanted to know what all the wires out of the radio are. and help would be awesome
i sell and i install those often... you need to plug every channel of your OEM radio into it, power it (B+, Ground, IGN) and from the RE-Q5 you will run singal cable (RCA) to your amps
You need a 4channel amp to run your speaker with a RE-Q5.. if you dont, you better get the RE-Q3 if its just for a sub amp
let me know if you have other question
personaly im installing a RF 3SIXTY.1 in my WRX
i ordered a five channel infinity, 50x4 and 150x1 and door speakers,sub, etc. . . where do you get the factory wiring diagram sayin what all the wires are from? or is are the wires the same color so i just match em up?
you mean the wiring colors code of the car or the RE-Q5 ?
no of the subaru wire harness. im sure the re-q5 will come with instructions giving the color codes, i just need to know what it is on the subaru side
1 - 5 of 5 Posts
