1 - 5 of 5 Posts
Well, I just got done installing my STI pinks with one minor glitch.. I am following the Cobb install instructions and am torquing down the lower control arm bolt at the hub to 116ft-lbs when I began to notice that it was not tightening. I had just gotten done tightening the other bolt for the strut so I'm pretty sure that the torque wrench was still set correctly. So before completely destroying it I decide to back it out and see what's up. And there it is an elongated hour glass shaped bolt. Is 116ft-lbs the correct torque spec? Although I've done suspension work on my truck working on a car is a new challenge. A couple of noob questions. I ended up jacking the car up along what appears to be frame rails towards the front. Any reason I don't see this suggested in other post about jack points. Also I managed to squeeze a bit of grease out of the swaybar disconnect. Can this be repacked? I headed to the dealer tomorrow to get a new bolt.. Hope I don't need to new disconnect as well.
Discussion Starter #2
I managed to locate some bolts at the local dealership. When I asked them to check on torque spec I was surprised to hear 89 ft-lbs :eek: for both the strut to lower control arm and the arm to hub connection. The guy double-checked it off of the computer and also confirmed that 129 is correct for the bolts on the front struts. Has anyone else double checked the Cobb instructions???
Wow, that's pretty lame if they COBB instructions are that far off.
wow that'll be an important flaw in the instructions IMO maybe you should email cobb 'bout that
Yeah 89 is the right spec. Just finished doing my spring install and couldn't remember off the top of my head so I torqued them to 100. No problems here.
1 - 5 of 5 Posts
