Mine sucks. It kinda squirts two separate streams on either side of the rear-glass ('08 WRX wagon) rather than the much nicer, even misting the front sprayers provide.
Do they all suck this bad? If not, I'm gonna hit up that dealership pronto.
The first time I used the rear sprayer I thought that it was broken, but have gotten used to it since. It seems to work ok if done correctly. A mist or some such spray method would probably be better but I don't think it's dealer worthy.
ya i think if it misted it would blow away. im totally content with mine. im not content with the front though cuz there is a spot on the bottom in the middle of the front windshield that i cant get clean unless i use a crazy amount of windshield washer fluid.
Mine does that also...I wouldn't mind, but it could at least spread the water a little better!
I haven't looked too closely at it but I imagine you could somehow replace it to spray 3 streams... or something
but it seems to work alright for me, just make sure you get some fluid on each side of the wiper blade and it should clean off the window pretty sufficiently
maybe you need to replace the blade? or use some better fluid?
yeah, mine sucked too. but now i have it disabled.
instead of spraying my rear window, i can prime my Water/Meth kit :)
i wish i had the same Headlight washer spayer like Pehon... we really need it in winter here with the calcium, i cant see a thing most of the time and have to wash/wipe my headlight regulary
