1 - 8 of 8 Posts
As title says, i'm trying to take out my rear shocks, but I didn't realize it's nessicary to remove the rear sway bar too?
I can't seem to bend the lower arm enough to get the shock out. anyone else remove their rear shocks on the 08's yet?
leave sway in.take the top nuts off first.then raise the car and remove the bottom bolt.pry down on the lower a arm .it will pop right out.
Worst-case, you could undo the endlink to give more downward travel to the control arm...
Rob
Remove the end link bolt and have a second person push down on the lower control arm. It requires a lot of strength/weight so don't expect to get it out by yourself.
We didn't remove the endlink, no wonder it took a lot of weight to push down on the hub lol
1 - 8 of 8 Posts
