1 - 3 of 3 Posts
The fitment of the silver trim ring around the HU and vents is tight as hell. I installed the IPod integration and OEM sub in mine last night, and getting that trim ring off was far and away the hardest part......
I bought a set of the nylon dash tools from Harbor Freight. After some frustrating moments, I found the wide bladed tool (like 3" wide) worked well. Just wiggle it in under the trim along the bottom edge and pry it up and out towards you. This will release the bottom edge. Then you can pretty much pull the rest of the trim ring off with your hands by pulling straight out towards you. After that it's pretty self explanatory if you've done some installs before. There's a ton of room behind the stereo for LOC's, IPod integration, NAV, whatever you want.
1 - 3 of 3 Posts
