1 - 14 of 14 Posts
I saw a post where someone drilled a hole in one of the restrictor pills to reach a lower safer boost level... What would happen if someone was to take out the restrictor pill? Would it hurt anything or help? Please let me kno.. ;D
Is this the 3/16ths mod? If I remember correctly, It involves removing a vacuum line restrictor and it's been known to cause weird boost spikes. Usually considered to be a bad mod.
restrictor pill needs to be drilled when installing a larger turbo. i put a vf39 on my buddies 2006 wrx and cobb reccomended drilling out the hole. it was such a tiny drill pit, ended up finding it in a dremel drill bit set, it was the smallest one they had
Pretty much allows more air to flow with less restriction so the hardware can function properly with increased capacity.
Soooo not really a good mod now?
Nope
i replaced most of my vacuum lines the first month i had my car. the stock ones didnt seem right to me.
Howd that work out? Did u put the resrictor pill back in?
as far as i know, my car was fine. i ran on stage 1 with meth, FMIC, and i turned up the boost a little with an electronic boost controller. i beat a stock STi and a lightly modded SRT4.
but that was a long time ago and i have been out of the loop for a long time. I'de say stick with the pill for now. If you move on to a bigger turbo, take it out.
Haha Wow thas alot of mods with a stage one tune... did it run ok other than being fast?
my wideband said the AFR was good, so i rolled with it.
1 - 14 of 14 Posts
