Thanks for the info. So few out there have done this there is little info.
So no axles issues? What is your camber setting now? Did you have to do anything to correct it, i.e. camber bolts in the bottom strut bolt, or did the stock camber bolt give you enough adjustment? What did you do about the sway bar, just add spacers to the links or STI sway bar?
FYI the caster, yes we should expect more of that, the STI and 11+ WRX arms add caster over the 08-10 arms, in addition to the wider track.
Any info you can give is very helpful for those doing this in the future!
Dragonfueled they are not that much lighter, a few pounds. If you want straight bolt on and Aluminum, 06-09 Legacy Spec B arms are what you want.
