Status
Not open for further replies.
1 - 2 of 2 Posts
So there is a stickied version of this, here goes, stock wheel and tire info for the 2008:
These are USDM specific, models from other countries may vary.
2008 2.5i Impreza (Premium alloys, not steelies with hubcaps):
16x6.5 inch wheels, 55mm offset, 5 X 100 bolt pattern, wrapped with Bridgestone RE92A, 205/55R16.
Wheels with Tire pressure sensor (with no tires) weigh approximately 20.2 lbs each
205/55R16 RE92A tires weigh 21 lbs each
2008 WRX Impreza
17x7 inch wheels, 55mm offset, 5 X 100 bolt pattern, wrapped with Bridgestone RE92A, 205/50R17
Wheels with Tire Pressure Sensor (with no tires) weigh approximately 23.2 lbs each
205/50R17 RE92A tires weigh 22 lbs each
(Thanks to hikeeba for the weight measurement on the WRX wheels)
2008 WRX STI
18x8.5 inch alloys, 5 X 114.3 bolt pattern
Standard wheel: 55mm offset, 25 lbs
Optional BBS wheel: 55mm offset, 20.5 lbs
245/40R18 tires, Dunlop Sport 600 tires, 26 lbs
info from iwsti.com: http://www.iwsti.com/forums/2008-sti-discussion/109354-2008-stock-wheel-offset.html
This sticky was lacking info on newer model years so posting this great reference for detailed wheel size info. Plus I am too lazy to cut and paste it all directly into this post ;D
http://www.cars101.com/subaru/tiresandwheels.html#impreza
I found cars101.com to be a good resource when I was researching buying a WRX and continue to use it for hard to find specs. This site is managed by a guy who works at a Seattle Subauru dealer http://www.cars101.com/subaru/contact.html so while not "official" I consider it to be reasonably authoritative.
1 - 2 of 2 Posts
Status
