1 - 3 of 3 Posts
Need some sound advice from the community on my build:
My first mod is some Feal coilovers. I'm going for aggressive handling but not so much every tiny bump throws my back out. This is for an 08 wrx sedan.
Do I put struts and sways on? Bushings and anti-lift kits? How much more do I need to go w the suspension so I can start this project sooner?
Open to any suggestions
No you don't need sways before coilovers but it depends on what you're after. You wont need an ALK setup but depending on how low you plan on going a roll center kit might not be a bad idea. Id also skip the bushings for the front/rear control arms until you need them as they are probably overkill for most people. I would suggest throwing in a set if Whiteline subframe inserts, assuming you don't have them and will be needing/getting an alignment once you get the BC's.
Thank you! I'm only wanting to go low enough to get rid of the wheel gap but at the same time I'm def wanting way better handling then the soft setup subaru left it.
1 - 3 of 3 Posts
