1 - 4 of 4 Posts
If anyone is considering a Torqued Performance map for his or her 2009 WRX, let me tell you it is more than worth it. Honestly this guy could be charging $150/map and it would be a deal. I just flashed my ecu with the Stage 2 map and my car pulls significantly harder than it did with the Cobb AP Stage 2 OTS map. I highly recommend this vendor. The throttle mapping was worth the upgrade over the Cobb map alone. I can't wait to buy an intake and try out the intake map.
One small issue, when I'm going to open throttle under mid-high rpms, I noticed that if I have to let my foot off the gas abruptly for some reason, the car will hesitate or buck a couple of times occasionally (not all the time). Could this be due to the weather around here (5-10 degrees F recently)?
1 - 4 of 4 Posts
