I am thowing a line out there to see if someone can help explain the table to me and how to tune it?
Anyone?
Cheers
Discussion Starter #2
Here is the situation.
I understand why it is there, how to gather the info to tune the table, but how the values actually relate to each other is a concept that I cannot get my head around.
It is probably an answer that I am going to go DUH, but for some reason I can’t see it.
As of right now I am looking at Cobbs info and one of my questions comes from the "Cobbs tuning guide".
It shows in the second paragraph that “A” data point in the image is -20% for a particular TPS Delta and needs to be adjusted.
Which cell are they referencing?
What am I missing?
Can someone help explain the different values in the table shown below?
[quote author=Cobb Tuning - AccessECU Software Calibration & Tuning Guides for Subaru’s v1.08”]
If your combined A/F Trim Immediate and A/F Trim Learned are -20% for a particular TPS Delta then you will want to make an adjustment. We have found the best adjustment to make to this table is ¬? of the recorded fuel trim value;
For the above situation you would want to modify the data points by remove 10 percent, which is ¬? of -20%. You can highlight the Enrichment cell for that particular TPS Delta point and hit the ‚ÄúM‚Äù key; you will then be prompted to enter a floating point value.?
The correct value for this particular situation would be .90; this adjustment will now tell your ECU for that particular TPS Delta you now want a 10% less MASS of fuel burst to enter the motor. After this adjustment is made your combined A/F Trims should be closer to zero. The further the sum of A/F Trim Immed. And A/F Trim Learned % is from zero, the further off your Tip-in Enrichment settings are from ideal. We suggest you tune so that your combined A/F Trim Immed. & A/F Trim Learned % is a small (14% or less) number.” [/quote]
Anyone have any thoughts on this situation?
Thanks
Ok so I was staring at this for a while trying to decipher what it's talking about. This is what I make of it. (Tuning super-noob btw). It looks like that for each of the TPS Delta values you also have a A/F Trimmed Immediate and a A/F Trim learned (If you have access to these values I would like to see them to further understand the process). The sum of these values gives you a percent (? or you can get a percent from them.) The further this percentage is from 0 the further away from perfection you are. The best method he found for altering the values to get closer to 0% is to modify the enrichment value by half of the percentage he got. So lets say that for TPS Delta of 7.81 he found that the sum of A/F Trimmed Imm. and A/F Trim learned was -16%. You would then highlight the enrichment cell for TPS Delta of 7.81 and type in .92, 1.0 - .92 = .08x100= 8%, (Enrichment = 352x.92 = 323.84). Hope I helped :)
I have been looking at this for a couple of days now and THAT IS WHAT I HAVE BEEN LOOKING FOR... The light bulb just went on!!!! THANK YOU = "+'s"
Hey sxhmidog.
Cobb is planning on coming out with the AccessTUNER software for the AP v2 hopefully pretty soon. Also Cobb has put out a tuning guide, which is where my question came from. Here is a link to the article that I am reading. Now in the article there are references to other guides... they are located at the end of the PFD.
Thanks again for the help!
http://www.cobbforums.com/forums/images/AccessTUNERSoftwareCalibrationTuningGuidesSubarusv111.pdf
Sweet man thanks. I've been sitting idle with RomRaider and haven't even tried to log anything. I need to get my butt in gear. Oh and fyi if you ended up with +16% you would need to use 1.08 to bump it 8% in the correct direction (For completeness sake).
The disconnect was the arbitrary TPS value (I thought that value was calculated), comparied to the TPD Delta.
I thought that I would throw this out there too. The "Unabomber" (On NASOIC) does an excellent job explains different aspects of tuning and where you can find additional information.
http://forums.nasioc.com/forums/showthread.php?t=795608
RomRaider... That is a good site too. Do you have the ability to log?
Yeah I have the ability but apparently no will to try, haha.
It is a pain in the butt to try to find a spot that is long, flat, straight, and free of fuz ;) ;D
