So I just got into track driving with my 2010 5-door Impreza 2.5i (please keep the laughing to a minimum) and am looking for some upgrades I can do to make it more fun/enjoyable. The first is looking into larger wheels. I have 16s on now, and wasn't sure how much larger I can go with the vehicle. Second, was something that one of my instructors mentioned which is an engine chip to program shift points and remap the torque curve. Is that a possibility with this car? Any other suggestions are welcome as well.
send an email to eric @ torqued performance, a stage 1 tune should help throttle response a lot on a NA engine
Other mods would be a good set of coilovers (i think your suspension would be the same as any 08-10 non-widebody WRX.
Headers and cold-air intake will also net you some marginal gains, i wouldnt bother with it.
Large tires, suspension and a stage 1 Opensource Tune will net you a lot of improvement at the track.
Go Get'em! racing a car is always fun, no matter if it makes 180 HP or 500 HP. it's all about going with friends and having a good time.
I think it's generally accepted larger wheels LOOK cooler, but at the cost of added weight. Instead I would look for a wider wheel, maybe 7.5 or 8" so that you can put a wider tire on there. I don't know what your budget is, but if you have the scratch, pick up a set of larger diameter, lightweight rims such as Volk or the classic Enkei Rpf-1s. Then you get the best of both worlds - lighter weight and larger, cool looking wheels that can accommodate a wider tire.
Oh yeah, and definitely contact Eric about getting a tune. His handle on this forum is "eminehart" btw. As mentioned above the throttle response is night and day!
  • Like
Reactions: shox101
^^+1
Rear sway bar is a MUST. You should be able to pick up a used one from a WRX or STI guy who's upgrading. Watch this forum, IWSTI.com & NASIOC.com.
As a matter of fact...if you're interested in a WRX OEM front swaybar with AVO urethane bushings, I've got one sitting in my garage.
It's a 21mm versus your stock 19mm. The urethane bushings make quite a bit of difference in how effectively the bar controls lateral pitching.
$60 shipped.
*Edit - one caveat I didn't see initially - "WRX sways cannot be used on the 2.5i (without modification) because of the exhaust routing...the cat section on the 2.5i usually hits aftermarket WRX sways. WRX sways will work on a 2.5i with modification though...as I'm doing, you just need to mod your cat section a little bit."
Sways and 2009+ wrx struts and springs would be a great $400 spent...IMHO. Also rear subframe, dif, and front cross member bushings are cheap and fun to DIY.
And to the OP, sorry for getting off the topic a bit, yes email Eric but mainly focus on cost effective suspension changes and buying used. If you want to do coilovers and tires.....that would stick you to the ground quite well!
And I happen to have a set of struts and springs I'm willing to let go (stock 09). OP can PM me if interested :)
