TWM Performance 2008 Subaru WRX Short Shifter in stock, ready to ship, still at pre-order price!
Hi everyone,
TWM is pleased to announce that we have recently completed final testing of the 2008 WRX short shifter, they are now in stock and ready to ship!
The specs for the short shifter are as follows:
-30% throw reduction
-1” shift knob height reduction
-Compatible with stock shift knob or any TWM Weighted Stainless Steel Shift Knob
-Available with optional polyurethane shift rod bushings
-Very simple installation, no modification of stock parts required
-One-piece construction shifter shaft, completely CNC machined without welds
We have designed the 2008 WRX short shifter with a reduced shift knob height, as well as a re-positioned pivot point for optimal shift feel and throw reduction. This is a true short shifter, which reduces both shift knob height and angular throw, not just a “chopped off” version of the stock shifter.
The short shifter is fully CNC machined from billet steel and is a complete replacement for the stock shifter shaft. The shifter also features a lifetime warranty as is the case with all of our products. The installation is straight forward and does not require any modification of stock components. Simply remove the stock shifter and replace with the TWM short shifter, typical installation time is approximately an hour to 90 minutes if you install the polyurethane shift rod bushings as well.
The short shifter retails for $129.95 without polyurethane bushings, or $152.90 with polyurethane shift rod bushings.
The optional polyurethane shift rod bushings eliminates unwanted play from the shifter and gives a more direct and solid shift feel. They are also available for sale individually for $27.95.
For the month of August 2008, we are still offering a very special price of $109.95 without shift rod bushings, or $132.90 with shift rod bushings.
TWM Performance’s weighted stainless steel shift knobs are also all compatible with the short shifter and can be purchased along with the short shifter at a $15 discount.
The short shifter is available here: 2008 Subaru WRX Short Shifter
Big August sale on Subaru Short Shifters!
TWM is also having a big sale on all our Subaru Short Shifters for the month of August 2008. This month only, you SAVE 20$ off the retail price of all TWM Subaru short shifters! The short shifters are Now Only $109.95,!
You can also order the Subaru short shifters with optional polyurethane shift rod bushings for $132.90!
Don’t forget to add a Weighted stainless steel shift knob and save an extra $15.00.
Also have a look at the new Shift boot retainer for all Subaru shift boot combined with a TWM Shift Knob. The new shift boot retainer is on sale for $14.95 and gives a clean look to the inside of your car by connecting yiour stock shift boot to any TWM shift knob!
Please contact us at [email protected] for any questions you may have, or if you prefer to place your order by phone please call us toll free at 1-877-655-0540.
Thank you,
Frank
TWM Performance
Discussion Starter #2
Re: TWM Performance Short Shifter for the 2008 WRX available for pre-order!
Bump for brand new short shifters ready to ship really soon!
Will this lever work with the OEM STI short shifter kit?
We did not have the occasion to test the shifter on a car with the factory STi kit, but if it turns out the same as the previous WRX generation with the OEM STi short shifter kit, it most likely will not fit. We will try to find a local car with this option to check that.
Thanks,
Frank
TWM Performance
The short shifters are in stock and ready to ship, still at the pre-order price, don't miss out!
We have decided to extend the sale and the special price for the 2008 WRX short shifter for the month of August!
Please contact us if you have any questions!
Thanks,
Frank
TWM Performance
