1 - 6 of 6 Posts
So the long and the short of it is my prosport boost gauge suddenly is not reading up to correct peak boost. Under wot, it will only hit about 10-12 psi then stop. Eric checked my logs, and it IS showing 18-19 psi at full boost.
So my question is, what do you guys think is going on? Boost leak? Why isn't it showing up in the logs though? The gauge seems very accurate besides the wot thing. So it's not like it's completely inaccurate. And it has shown 18-19 psi max in the past. Just not recently.
Any advice or direction would be greatly appreciated! TIA
Steve
Clogged inline filter if there is one?
Yeah, I feel like the fix should be something simple like that. I can try and contact prosport and see if they can send me a new one. Thanks for the suggestion.
It's weird. The gauge has worked perfectly since I installed, barring one incident. Now it just doesn't want to read up to full boost. I haven't changed anything. All I can think is to look at the filter, and check the hoses for cracks or splits. Beyond that, it's gonna be a phone call I think.
I had the hose crack on mine. Was only two months old when it did it too.
1 - 6 of 6 Posts
