I wanted to know if anyone has ever done this, or if anyone knows if it will work.
I was here trying to decide if I wanted an Oil Pressure gauge or a Oil Temp gauge but I really only have room for one gauge. I had a thought, instead of the oil pressure gauge, I see these aftermarket Oil Pressure light kits and many of them have adjustable switches that turn on a low oil pressure light that you mount on the dash. But since the factory low oil pressure light is like a 2.1 psi switch, and it simply makes a ground to turn the light on, I was thinking that these adjustable light kit sensors do the same thing. So If I buy a 1/8 bpt sensor and put it in place of the 2.1 psi factory one, I will have an adjustable idiot light. I found one that can be adjusted from 0.5 to 24 psi and I thought that would be perfect, maybe set at like 15 psi or something.
What do you think?
