So, the first rains in So Cal finally hit and off I went to see what the STi can do in the rain against its many settings.
First off was DCCD Auto and VDC on (or on delay).
The car felt very stable and accelerator work on straight lines was very easy due to the tq limiting factor of the VDC. DCCD Auto was also nice for the straights for more grip to all 4 wheels.
In the corner however, was a different story. Braking was ok, once again on the straight lines, the system works fine. Massive amounts of understeer from the VDC braking and tq limitations. From the driver's seat, in the rain the VDC acts to use the outer brakes in the corners. This caused massive understeer as even the heading wouldn't change let alone actual vehicle direction. Coupled with the DCCD on auto trying to put more power to the front since the rear wants to slide = even more understeer.
Mid corner braking necessary to change brake balance from going too far outside. Throttle also doesnt really help because of DCCD trying to pull vehicle out of the corner as opposed to pushing the rear qoutward to change heading and direction. At the same time VDC is limiting TQ and braking the outside wheels. Very frustrating.
