This is my first "How To" that i have ever made, so bear with me.
CoolingMist Water/Meth Injection kit from www.importimageonline.com. $185 shipped.
First disconnect the battery.
After that, jack the car up and remove the driver side wheel.
Next, remove the clips from the inside of the fender well and some of the ones on the wind splitter under the washer fluid reservoir.
Drill the hole in the lowest point on the reservoir(make sure you have a bucket).
make sure that you use the Teflon Tape on anything that will be threaded.
Mount the pump and run the hoses and wires.
Remove TMIC
Drill and Tap the TMIC
Put the TMIC back on
Stock?
It's impossible to see the nozzle so i put the camera under the intercooler to get this pic.
The whole install was pretty simple. All you have to do is read the instructions that come with the kit.
Remove TMIC
Stock?
