1 - 20 of 48 Posts
so what oils do u guys use for thos that actualy have done some testing on it
( diablo what oil do u use i forgot to wright it down )
Castrol Syntec 5w-40
I use mobil 1 10w40 fully synthetic, alot less shearing than the 5w30 (which shears really bad)
Yes, yes it does:
edit: I just noticed that is the extended performance sku, not sure how different it is from the non-ex-per.
IM a castrol fan....
[quote author=therussiann]
i hurd lots of rly good thing about mob 1 5w-30
[/quote]
u hurd rong dood!!!
Mobile 1 *used* to be a pure synth with PAO/ester base but it made a switch after some nasty litigation involving a lawsuit with Castrol and the use of the term "fully synthetic"
Long story short, Mobile 1 is now and forever will be pretty shitty, shear happy refined mineral stock.
OK, FOR THE RECORD:
DO NOT USE MOBIL 1 10w40 fully synthetic in an 08...our cars call for an SM-rated API oil.
10w40 does not have an SM rating (it is only SL), the 5w30 does have an SM rating...but it is crappy
I feel really dumb for not noticing this, I've used it in my past imprezas, but I forgot to look to see if they updated the standard...AND THEY DID!
I'm changing my oil to something else immediately!
I have not noticed any problems as a result, I've only had 10w40 in my car for 5k miles or so, but it's going to be changed asap.
Note: Don't count on your dealership to know this, mine didn't.
why are you using 10w-40? isn't mobil's 10w-40 for high mileage vehicles? all there regular oils (like 0w40, 5w30, and 10w30) are all API SM certified and have every standard certification they can get. i can't imagine they're bad if they've passed every commonly used national and international standard. not to mention it's standard/approved for use in several high performance cars (vettes, vipers, porches, bmws, etc). not saying it's the best oil you can buy, but it's not bad.
Well, I was dumb, to put it simply.
I used 10w40 in all my old cars which only required an SL certification, and I figured a "High Mileage" oil wouldn't "hurt" if it had some extra protection. I usually prefer 40 hot viscosity so if it shears a bit, I'm not running an oil that is way too thin.
I was dumb and didn't bother to look at the actual specs of the oil...so now I'm changing to Castrol Syntec 5w30 fully syn...until maybe I go to a more expensive oil.
Well that sucks I just put Mobil-1 5-30 in today. Is it at least better then regular oil?
What should I use next time?
Mobile 1 5W30 is a great synthetic, there shouldn't be any issues running it.
I use AMSOil because of preference and I get a deal on it via a family member.
1 - 20 of 48 Posts
