PCV location - 2008 wrx ?
3 reading
5.2K views 11 replies 5 participants last post by  rexassian
#1 ·
Under IC?
#3 ·
Yeah that helped, I found it...thanks my friend ! alhough I could not remove to check because i am missing my deep socket 3/4 inch ! I was going to spray it out, getting a lot of white smoke from exhaust and not seeing any oil on ground or under plastics....
#6 ·
Dealer called, bearing in turbo bad, shaft loosened up and broke seal, hence oil getting through and smoking out exhaust......new turbo going in covered under warranty
Thanks to all for your insights!
#9 ·
what color smoke?? is the car using oil?
#11 ·
not good. are you still building good boost? sounds like cracked ringlands or bad turbo seals.
