Tactrix
1.9K views 5 replies 5 participants last post by  radekkacz07
#1 ·
What is the difference between the Tactrix 2.0 cable and the Tactrix 2.0 cable with full adapter set? I am going to order this cable today and want to know if I need the adapter set for my 2009 WRX or if I can just get the cable. Thanks.
#3 ·
All you need is the Tactrix 2.0 "cable" (just the OBD2 attachment piece, and the USB cable to go into your computer).
I believe the adapters are for jumping the diagnostic connectors in older WRX's and possibly Mitsubishis.
The 2008+ WRX does not require and fussing with connectors. Just plug in the Tactrix cable to the OBD2 port, flash a map, and you're good to go.
#4 ·
My friend has a tactrx cable for his Evo9. Do you think it would work for my 08wrx?
#6 ·
Ok. Thank you for a fast reply. I am not sure which one he has. Ill ask him :) at least now I will know for sure :)
